S
Seamaster111
Guest
Somebody once said " If it ain't broken don't $#$@ with it ".
Tried some Joe Gunn made mini 8, the red stuff, and couldn't get it to tune below 1.3 or 2% reflect. Installed my original coax and got the same as before 1/2% reflect 1<img src=http://www.wwdx.org/smilies/posticon1.gif ALT=":1"> . Check continuity before installing. The antenna 10K just wouldn't tune below 1:3 on the 259B.
I was told this was good coax, any body else have any experience with the Joe Gunn red coax, and why does this happen with different coaxs?
Both coax are mini 8. Gotta use the small stuff. Only running 1x2 and 1x4 no volts.
The red stuff does have a excellent braid and stranded center conducter. The Joe Gunn stuff is supposed to accomodate power better, with regards to the mini 8 type.
</p>
</p>
