I
Icom 706 King Cobra
Guest
obviously there are many antennas out there..
as there are different types of coax..
yet as one goes to coax dsigned for lower losses to combat the higher losses of using vhf & especially uhf & higher frequencys..
it seems thatthe HF coax runs use mostly PL-259 or slightly better UHF connectors..
However it seems nearly all feedlines designed for uhf or higher frequencys instead use N connectors..
So what makes these connectors better..?
I have seen same antenna made 2 ways..
one with UHF connector & other with N connector..
The one using N connector shows a higher gain..
(yes i know it is only a db or so..still is higher)
Ofcourse N connectors are quite a bit more money as well
P.S. did anyone else see tech TV's latest show..
it shows some things inside F.C.C. labs
and also speaks of high speed internet over power lines..
</p>
</p>
