I have been running Cablexperts 1318FX for a while now and have had very good service from it,fairly flexible, good stuff. I have used Belden 9913 in the past, but you have to be careful to keep the radius of the bends large, if you kink it, the center conductor will shift inside the cable(another problem with air core)...then you have a impedance bump in the line, good foam core is better IMHO.
<span style="colorrange;font-family:helvetica;font-size:large;">RadioActive</span>
</p>
</p>
