B
BOOTY MONSTER
Guest
does the coax running inside the mast , like in the starduster design , have a choking effect on CMC's ?
If you check the old Sigma 4, manual you will see they suggest a similar install. They don't make any other claims in this regard however.
BM, for years I have set my Starduster up using an 8' x 1.25" mast, a 8'4" coax jumper, a barrel connector, and a hose clamp.
I can't tell you for sure it worked as intended, but it seemed to do the job and for sure when I used a little power.
Eddie, I'd be getting some self amalgamating tape or another waterproofing agent on that join, as it is, its a recipe for disaster, once water gets in that coax, its fecked.
I do know the AP needs an unpainted mast to ground to to perform right. But as far as the coax in the mast deal with the SDer i don't think it matters.
