Should I buy jumpers that are the same type coax as my long runs. Im thinking yes. What do you guys think?
as long as its quality coax with quality pl-259's thats assembled properly and will handle the power there shouldnt be any issue .
"its a good idea to keep them very short (under 3 or 4 inches) or 1/2 wavelength long not forgetting the velocity factor"
I must be misunderstanding what you said! The length of a typical 'jumper' should be long enough to reach from here to there, and that's about it. Length just doesn't matter as long as the characteristic impedance is right (50 ohms normally), and there isn't a lot of losses in whatever kind of coax you used.
And as for an 'electrical' 1/2 wave 'jumper', I can just see several 60 feet long 80 meter 'jumpers' piled up behind my desk. Or maybe 130 foot 'jumpers' for 160 meters? That's just not necessary, and kind'a silly, isn't it? I change bands fairly often, and never change the length of the 'jumpers'. Hasn't seemed to make any difference so far.
MR;Clean I would take Doc,s advise on this or any other subject, as for Jazzsinger Its like talking to a political service hot line??? Maybe he,s running for office ? I,ve bin into radios for 35 years & never used a 3 or 4 inch coax jumper on any set-up. As for mixing cable here not a problem here. Just my 2 cents! Bob "cordova lucky 13"
