I just was wondering what is the max length of coax I can or should run? The reason being I just got a solarcon a99 and I'm trying to decide where to mount it. Any thoughts?
If we lived in a perfect world where coax had no losses, then it wouldn't matter. However, it really does depend on how much loss you are willing to accept.
Lets say you are transmitting 100 watts into 100 feet of:
Belden 9201 (RG-58) you will get 63.29 watts out
Belden 9258 (RG-8X) you will get 69.854 watts out
Belden 8267 (RG-213) you will get 78.543 watts out
Times Microwave LMR-400 you will get 86.403 watts out
NOTE1: Data above from
https://www.qsl.net/co8tw/Coax_Calculator.htm
NOTE2: Data above assumes a perfect SWR match at freqnecy 27.18 MHz.
So to answer the question of how long of a coax run you can effectively use depends on the length you need to run and the type of coax you plan to use. With the example of the Belden 9201 RG-58 coax above, after 100 feet of coax you have effectively lost over 1/3 of your transmitted power before any of it ever makes it to the antenna.
I guess what I am trying to say is, to give you good advice, we really need more information on the type of coax you plan to use and the different lengths of coax needed, as well as the different heights of the antenna in question.
The DB
