I need to know what is the better stuff to go with, Ill need around 140ft for this move....
And my neighbors are close to me as well ....
Been looking at the LMR 400UF coax, its like 1.44 per ft, and the regular LMR 400 coax is less than this....( priced it at davis rf by the way )...
Trying to save some money here.....if I went with some of the LMR 400UF coax and used this for the choke, and coming down the mast pipe....then use a barrel connector and go with the solid LMR 400 coax to the radio, would this cause a problem ?...
Or should I bite the bullet and go with all LMR 400UF coax ?...
