The following quote is from the SIGNALENGINEERING/ULTIMATE web site
"You can try to eliminate this situation (called "Common mode currents") by winding an "RF Choke". Wind about 6ft of RG-213 or RG-8 into a coil (6 to 8 turns). For RG-58 use 4ft with 6 to 8 turns. Wind the coax up, placing each turn right next to one another. Use electrical tape to secure turns together. You should place these as close to the antenna as possible. Right at the antenna coax connection point being optimum."
Does this really work? Is it as good as installing an actual Balun? I have my beam ready to put up, and I want to get it right the first time.
- 399
- 399
