I wonder what the impedance transformation would be using two feet of it as a meter jumper.
Unfortunately it is impossible to predict the change in X and R without knowing what they are to begin with. However, if you are familiar with using the phase angle and the magnitude of Z for impedance measurements as well, these are the phase shifts you should expect to see...
Channel 1, a phase shift of 29.89 degrees.
Channel 19, a phase shift of 30.14 degrees.
Channel 40, a phase shift of 30.38 degrees.
If you are going towards the source (radio) from where the measurement was taken it will be clockwise, if you are going towards the antenna it will be counterclockwise.
So if you started with a reading of R = 50 and X = 50, with a 2 foot jumper connecting your analyzer to the antenna, your antenna would be very close to having an actual R = 35 and = X 35.
If I went the other way on the feedline, say I knew my antennas impedance and wanted to know the impedance on the other side of the jumper, then you would get a reading close to R = 90 and an X = 55.
Just in case you are wondering, all three examples would have an SWR of 3.4:1...
These figures are assuming an exact 2 foot section of coax with a velocity factor of .66.
The DB
EDIT: My phase changes are correct, but the X and R values calculated later are not, I missed a step... I used 50 ohm coax for the adjustments instead of 100 ohm... If I get time I'll recalculate later today...
