Cobra 146 (not 148) Bracket
The 29's are 7 and 1/2 inches
The 25s are 6 and 1/2 inches
How long accross is your 146 ? Give or take a 1/4 inch or so. :)
They have these adjustable ones and there stronger and better then the ones that come with radios and there under 5 bucks.
the 146 case is 7 and 1/4 inch plus the rubber washers so the bracket would be 7.5 inch or a little less.
hotrod im not sure what you mean but if your saying they are the same bracket they are nothing like the same bracket as a 148,
148's and grants use the wide 4 thumbscrew multi angle bracket like other exports,
the 146 is the same chassis as an ar144/ax144/stalker9fdx and uses a narrower twin screw bracket.
ohh.i thoght they were all the same cause the 146 and 148 i believe are the same
size.h,w,d. but come think of it the 146 does only take 2 thumb screws
  • @ Geoexplorer69:
  • @ Geoexplorer69:
