You were correct R44 is tied to RX 8V, and that is where I tied it into.
By changing the value to 8.2K and tie it to the same spot I tied VR402 to (8V constant) will effect the voltage and
I did move the orange wire on VR402 to the + side of C84 (8v all the time).
R175 was a 2.2K resistor in series with the other side of VR402 and went to ground. This is back in (not shorted out)
The center wiper of the VR402 had a 22K in series going to junction of R44 and D51 and that is jumped and so is D51.
Both D51 and R174 are jumped out and D52 is clipped out.
With the 8.2K added in from constant 8v to junction R44/D51, I can now swing the voltage at that point. The swing is not a peaky as before .
Clarifier knob is centered and reception of channel 19 is good. I can swing channel 19 off center both ways. How much I dont know but with the clarifier fully clockwise I can hear some channel 19 traffic on channel 18, but not 19 on channel 20 with VR402 counter clockwise. So the swing is more in one direction than the other.
I think it will work ok this way.
Thanks for sticking it out.
There is a CB repair shop at one of the truck stops on the interstate , I think I will take the radio there and have them check the freq swing for me.
Larry
Larry
