I am sort of running around in Circles. Driver, Final, Predriver all check good. All voltages at the PLL are good and 10.240 on pin 8. VCO block all voltages are good. Mixer all voltages are good. But my highest Freq. is I believe 34.XXX MHz? I do not understand that one. Transmit Inhibitor. switch is good. I see no Freq. at the final, driver or pre driver but all voltages are correct there. also the voltage regulator has all correct voltages and the AM regulator also. I checked a few Caps and what I checked were good. I will change them eventually once I find the problem. No one has ever been in this radio before. and the PA works and I can hear a change in tone on a test radio sitting next to the 148. What am I missing?
Edit. Forgot to mention the RX/TX light does turn from red to green.
