The radio has a pretty much standard peak and tune with a cap mod and variable key. R131 cut and if I remember correctly VR11 was turned up for the ssb output. When working on all 8 cylinders it's an exceptional sounding radio.
Every now and then the radio's output starts dropping on my meter and you can see the SSB output drop from 17 watts to 3 watts. The AM falls off to the point where full key which is normally between 6-7 watts drops to 1/2 watt.
I have enough replacement radios to last me a lifetime but if anyone has a suggestion what might have gone bad, that would be great.
I turn off the radio and the next time I key the radio it's back to normal. Sounds like something is heating up.
I just need some input and if it's easy enough requiring just a part change, I could do it.
