S
saint7ds
Guest
Hello all
I recently got a cobra 19xs for two dollars at a flea market. I bought two of them so I could play around with tweaking and seeing what everything does in a radio.
I took one of the radios to a friend's house so he could play with one. After putting it on a meter, it deadkeyed 2 watts and swung to 6 watts. After a few hours, he had it deadkeying about 4 watts and swinging to 20 watts on channel 20, 15 watts on channel 1, and 25 watts on channel 40. Everything seemed to work fine, so he buttoned it up and I took it home to put it in my car.
Well once I hooked it up, I had no recieve. The meter on the front wasn't even moving either. I hooked up a PA speaker and it worked just fine. It's transmitting okay, near as I can tell (the meter swings when I talk). I read it might be the voltage regulator but I'm not really sure.
He turned quite a few of the slugs inside and spread apart some of the coils that were inside. It was a test radio anyways so i'm not mad. I had even anticipated having to work on it from the beginning. Now i'm wanting to see if I can fix the problem. Any help would be great.
</p>
</p>
