The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
I have a 2000 that whenever any power mic is hooked up tp it it squeals on recieve when volume is turned up. Anyone ever see this and whats the fix please.
Seen this happen quite a few times with the 148/2000/Grant type radios. Check to make sure that there is no connection between the audio ground (pin 2) and the switch common (pin 4) on the mic plug.
Ill check that tomorrow I have seen 148 and grants also do this I just never owned one so I never dug into the problem interesting how it squeels only on recieve and with volume over certain levels halfway or 12 oclock on volume knob and lookout for one hell of an annoying hetrodyne screech.
I agree with space cadet. I've seen that problem many times, too, always comes to the same cause, whether in the mic plug oir in the radio at the mic plug area.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
