Cobra 2000mosfet
BAGEBOY
117
14
46
What is the agenda pep power of a cobra 2000 when it is molded.with a mosfet
Saw local use a Rt1 mosfet instead of a irf5@0 said.it was a bit better on the meter have seen a few mods but I am looking for the most effect mod
I would not worry about getting more power out of it. I would run an amplifier with it. If you can get more power, the power supply won't be able to handle it as it can barely run a stock radio. The power switch is the next weakest link and becomes problematic even at stock power levels.
I saw a few.modded so.i was curious
Approximately zero once the power supply is damaged and shuts down. The power drain of a MOSFET final will prove too much for the radio's factory power supply.
And if you're willing to power the radio from a larger external supply, you might see 20 Watt peaks or so if everything goes perfectly.
Reactions: 357magnum
