B
baconater357
Guest
Hello, on the Cobra 25 WN,NW,ST on the Audio Chip Amp,,where it is soldered, there are 2 short Black wires added to the solder, and the wires go to the Audio Chip connections, does anyone have a pictire or can you explain where these wire go to and from. They got remove on a re-solder, and unknown where they go, cannot find a schematic for the life of me. Can any one post a pic if possible, and or explain where to and from the wires go. Thanks you in advance...If no idea on this , the radio will be used for parts, or the land fill. Thanks,,,
