I have a meter comming, tracking says it will be here today, and its a 3 face so i can at least get a quick shot to see them. There is something I forgot to mention. When I got this meter, the inline fuse was bypassed with foil. It worked okay at that time. When I discovered it, I replaced it with a new one. When it DID work, unfused, it would work great, then at random times phase out until you heard nothing. It would not RX or TX and the guage wouldnt move. The power stayed on the whole time and didnt dim the lights. A few *light* taps on the top would make it come right back in. Checked the ground, all good and tight. Reflowed the solder joints from the antenna and other ground spots. Thinking about changing the final from stock to maybe a 1969, but i need to look at the datasheets to make sure if they're compatible.
I will get back to you when I get this meter. Thanks everyone!
CableGuy
