I've got a Cobra 29 LTD Classic that works and preforms great , as a base radio . But if you put it in the mobile , it works until it gets jolted somehow (bumps and so on) . I figured it most have a loose wire or a cold solder joint somewhere , so I went all through the radio with a magnified lens and flash light .
I found nothing , so I thought I'd ask here and see if anyone might have any other ideas for what might be causing this problem . Any help would be appreciated .
Thanks
Thanks
