Howdy everybody. I have 3 options for tuning my cobra 29LX.
A. 4w carrier swinging to 25-35,
B. 5w carrier swinging 38-45,
C. 15w carrier swinging 75 (rfx-75)
Which amplifier would you recommend for each setting? Maybe an Xforce Mosfet 400 for option C? what about A and B? Any help is apprieciated.
Thanks
Duster your thread here has gone off on an amplifier bias debate. There are plenty of links and threads for that. That said here are two amplifiers that will work depending on what tune or setting you choose on the radio.
TNT 350hd
Transistors 2 x 2SC2879
Dimensions H 4 1/4' x L 7 1/8' x W 41/4'
Amp Draw (maximum) 29
Class B biasing
SSB Delay auto
Pre-amp yes
Driver Required N/A
Power Output (RMS) 150 Watts
Power Output (PEP) 400 Watts
Driven Power (RMS) N/A
Driven Power (PEP) N/A
install recommended with 8ga wire
and 50a fuse. Max input carrier of
5w or 120w max carrier from amp.
Max peak input 120w.
Price: $232.99
TNT 600hd
Transistors 4 x 2SC2879
Dimensions H 4 3/4' x L 11' x W 6 3/4'
Amp Draw (maximum) 100
Class B biasing
SSB Delay yes
Pre-amp yes
Driver Required TNT 250 (optional)
Power Output (RMS) 300 Watts
Power Output (PEP) 625 Watts
Driven Power (RMS) 400 Watts
Driven Power (PEP) 1000 Watts
install recommended with 4ga wire
and 125a fuse. Max input carrier of
20w or 300w max carrier from amp.
Max peak input 240w.
Price: $375.99
I think you could also make a Texas Star 500 work as long as you went with a lower setting on the radio.
