Click here to find out how to win free radios from Retevis!
I don't think you'll find a supplier of this item, due to age of product. However, may I suggest a custom modification? Fashion-fit a freq counter in there...
I hope you found your clock.I had the same problem once back in the early 80's.I had a clock lying around the house that had the flipover numbers.It fit and worked perfect.Im needing the pushbutton off / on switch for a 135 right now.Anybody out there got an old junk or parts only 135 lying around ?Thanks
Did you ever find a clock for your 135? I just got a 23 channel 135 off of ebay.I needed it for the power off and on switch for my 135 40 channel.I'll check the clock out and see if it works.Let me know if you are still needing one.
