B
bull8042
Guest
I keyed my mike last night and my speedometer died and the brake light and ABS light came on. After a few minutes, the speedometer started working again. After stopping and restarting the truck, the ABS was happy again. I tried keying the mike again, only to get the same results except this time I also got the check engine light. HOWEVER, after restarting the vehicle, no good! Speedometer still won't work and the dummy-lights are still on.
I have changed nothing with regards to the radio or supply power. However, I have just moved the antenna to the rear of the bed and installed a new 18' cable. I have been talking on this radio for a couple of weeks so far with no problems until today.
'99 Dodge Ram 2500 4WD, Cobra 148 GTL, 18' coax with Firering connector, 36" Firestik II.
The power is connected directly to the battery via fuse and shielded multiconductor. The shield is connected only at the battery end. My battery is a new Optima Yellow Top and I am running a 120A alternator. Nothing else is powered on this power cable.
I also have a Truspeed speedometer calibrator under the dash.
Anybody seen anything like this before?
