B
BOOTY MONSTER
Guest
its pretty much generally said/accepted that if a coil must be used on a mobile antenna that the higher the coil the better . its also said that a coil forces or directs more current or signal up the antenna above that coil ........ if those two statements are true then the higher coil is forcing more signal into a shorter stinger . so even though the antenna may be the same overall height and the coil design (diameter/length , # of wraps and spacing) may be the same moving it up it supposed to be better .
the thing that im not getting is that it doesn't make sense to me that if the coil is forcing more signal into the section of the antenna above it that having more stinger/antenna above the coil gives more length for that signal to radiate . and if the coil forcing more signal up the antenna is true doesn't that mean there is less signal below the coil ....... so a top or near the top loaded coil reduces the efficiency of the shaft/antenna below the coil but but the few feet above it is stronger .
do coils really force more signal up the antenna ...... or do they just simply shorten the antenna ?
