Click here to find out how to win free radios from Retevis!
Stone Crusher, the only advantage to having a two coil is to shorten the overall length only. A two coil performs just as well or maybe a little bit better. Kale
Hey Kale thanks for the quick response now I'm just woundering how the guys that are running these like em? Do they hold up?? How are they performing??
I have a Mr. Coily here, it has a 21" shaft, I also have a 10k mounted (22"). I am only using the 10K antenna at the moment, the 10K tuned just a little better better than Mr. Coily for me. I have the antenna mounted on the roof of my F150.
I never really run the Mr. Coily that much, for it puts a little more strain on the roof being that it is bigger is size.
Hey guys I'm thinking about buying one of these Bad Boys maybe two but would like some opinions first.Is there anyone using these antennas and what are the advantages to having the double coils?
454 Crusher Back out!<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/nerd.gif ALT="8o"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin">
Good to hear from you guys and thanks for your input! Glad to hear there working so well for ya maybe I'll try one of each of those seeing that there very comparable.To bad for the weight issue but I might be able to make the coily work on my pickup a little easier than my big truck! 10-4
I've been running a Coily on my PU for several years and have been very satisfied with its performance. I have a single coil model with the 27 inch mast. I have it mounted behind the cab.
Sorry I didn't get back to right away but glad to hear your happy with the antenna it looks great on there I can't wait to get one! Take care!<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT="">
Yep... Both of the front ones are... The rear one is a common fighting stick, also done by 55... that is a single hot set-up the center 55 is the driven antenna...
I have done a few local keydowns, have taken out a few 16pill set-ups with my 8pill and also dropped the maul on a 20pill armadillo... I am not a power house but the antenna system does work really well... As for big keydowns I have been to a few but haven't keyed (yet)... The truck is still a work in progress, but it is also my daily driver... I just got my leece installed and charging my back battery bank so I am one step closer...
