Im looking for a pretty good powered connex for my mobile. what should i get. im not looking to spend all the money on a the 300 watt model but the 4600 is looking pretty good right about now. any opinions.
DTB Radio said:If you're limiting yourself to Connex and don't have more than $400 to spend, go for the 4600. Personally, I'd go with the Stryker 490. It costs alot less, will give you 130-150 watts, and you wont have to run crazy power cable for it. In my opinion, the transmit audio is also better in both quality and over-all punch than any Connex, assuming proper tuning.
Crazy Eddie said:DTB Radio said:If you're limiting yourself to Connex and don't have more than $400 to spend, go for the 4600. Personally, I'd go with the Stryker 490. It costs alot less, will give you 130-150 watts, and you wont have to run crazy power cable for it. In my opinion, the transmit audio is also better in both quality and over-all punch than any Connex, assuming proper tuning.
DTB what kind of amperage do these 490 radios pull?? I have a 10amp power supply in my truck, currenlty using a Stryker 440-hp looking to upgrade to a 490-hp for more powa!! will power suppply be enough for the 490 ??
Thanks
Mr Clean said:Get you a connex 3300 or Gen Lee and a 2 pill. It will rock for about the same money.
