It can certainly be done. Since I'm not familiar with that 'matching unit', I can't give any advice about using it for matching that whip to 11 meter use. Depending on just how much trouble you want to go to, and if you think you may ever need that 'matching unit' in any kind of repairable/working shape, there are several ways of getting a reasonable match. Most of those 'ways' would involve destroying that thingy or just by-passing it. Not using that 'matching unit' and by-passing it would probably be the simplest way, but if you know much about radio stuff it will be noticeable, would that work for you?
