So I was thinking the A-99 is worthless as tits on a boar hog... but the thing is about 16.5 foot long... so I tore mine apart
The top element is around 70" long and the middle is about 68" long... for a total of about 138" when the center and top sections are added together
Then I put the bottom section in a vice and grabbed a 24" long pipe wrench... place the pipe wrench on the metal section and started turning... POP went the element on the inside... lol not gonna lie I was happy, turned it a few more times and was able to get both end caps off the main fiber glass tube...
next on the list is soldering up a 60" long piece of wire to the top cap, then attach it to the feed line inside the A-99
finally I will make a hub for the radials... not sure if I should slope them of not, and still on the fence about weather I should go 1/8 wave or 1/4 wave on teh radials
I will get pics up in a few minutes
