Hi everyone, here is the most puzzling issue I ever encountered. I just bought a lp-100A watt meter and I checked my output and swr with a dummy load in line with amp on. My swr on ch1 - ch20 - and ch40 are all 1.1 now when I put my antenna in line, my swr on ch1 - and ch40 are low, 1.1 BUT....on ch20 it climbs over 4.0, on a dead key....but...if I audio check the swr then drops down to 1.1. I am stumped on what this is all about. If the amp is off, the swr is low on all 3 test channels. But like I mentioned if the dummy load is in line I dont have this problem. Any ideas???? Thank you.
