Maybe someone can share their knowledge and experience with this mystery. I have never encountered this before but here goes. I have a Number 5, 5/8 ground plane antenna. It's mounted to a crank up tower. I'm running 213 as my main run of coax. Tuning on MFJ shows SWR 1.1 R-51 X-1 or 2 depending if it's windy. Tuned to 27.025. Now here's the weird part that I can't explain, I apply about 500w-600w to the antenna system talk for a couple of minutes. I start to notice my SWR going up so I remove my coax and take a MFJ reading. SWR 1.6/1.7 R-36 X-19. Then I wait a couple of minutes without transmitting, take another reading the numbers start dropping. Within about 5-6 minutes with no transmission the numbers all go back to it's original state SWR 1.1 R-51 X-1 flashing 2.
Has anyone encountered this problem or heard of this happening? If you could lend some help with this I would really appreciate it. Thank you in advance.
