D&A RADIER BASE AMP...
AMPOWER
BANNED
Mar 30, 2005
203
3
Illinois
It has 4-6JC6A tubes in it....at say 100% test tubes...what can i see out of this amp????
Is there any up grades for the 4-tubes??
AM POWER
Howdy,
If you look a little closer at the tubes, they should say "Six Jay GEE Six", not "Six Jay SEE Six".
With those tubes, 70 to 100 Watts carrier, 350 or so peaks would be reasonable. Might show less. Tube testers don't put more than a tiny trickle of current through a tube. Doesn't push the tube to it's current limit. Makes it hard to tell where that limit will fall.
Types 6JR6 and 6JT6 are about the same size. The 6KV6A is larger, and tougher to boot. And rare. Might see more power with that one.Not much, but more.
If you don't put some fixed bias on the grid pin #2, they may overheat with the carrier turned too low. Or too high. As a rule, you'll find pin 2 soldered directly to ground.
And one of those thirty plus-year old filter caps may go "SNAP" and plaster its guts all over the underside of the chassis.
Ahhh yes you are correct ..Thank you :)
They are 6JG6A tubes...
I think ill send it to justin sometime and have him take a peek at it and fix a few things that im shure that need to be fixed and or upgraded...:)
The tubes are SYLVANA in grey or silver letters...i know there are some green and white lettered tubes too...wonder if those would make a difference??
AM POWER
If only Nomadradio took Internet business! He would be the guy to send it to! 8)
Besides, Justin is not a big fan of sweep tube boxes. I'd be surprised if he would want you to send it to him.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
