detachable PL-259's ?????
  • Start date Start date
Those are junk
I have to disagree. My Diamond K-400C mount came with a cable that had the PL-259/FME connector on the end and it has worked great for the last six years.It is used on 2m/70 cm where even a slightly loose connection will cause a high SWR.Unless you are running tons and tons of power they should not be a problem.
I was pretty skeptical when I bought my first one like that but after a little over a year everything seems good.
Well that one looks well made and the one in? does not.
