This has been posted before. I never got a good answer.
I have often wondered if there really IS a difference between DIAMOND or SQUARE loops for a quad antenna when it comes to polarity and performance. Which one works better or are they both so close we would be splitting hairs.
The ham radio antennas seem to use squares while the CB world tends to use diamonds (Avanti, Maco, Signal Engineering, etc).
Aesthetically speaking, I like the "looks" of the diamond loops, but the square loops with the x-braces sure look BIG!
Feeding the diamonds have the advantage of using the spreader as a support for the feedline, where you usually feed a square in the middle of the loops rather than the corners.
I'm curious what YOU think!
