I'm looking to build a 1/4 wave 11 meter CB Ground Plane antenna, like the one Radio Shack used to sell. Does anyone have the dimensions for the radiator and radial lengths? Thanks!
Thanks! Very helpful!Try this using 4 or more stainless steel 102" whips, a mirror mount L-bracket, and one of more hubs from an A99. I have several homemade hub and I also make one that only uses 1, 2, or three slanted down radials. The more radials I use the better the antenna seems to work at my location.
You don't need the pipe attached to the side of the antenna, just tape the coax close to the mast. Works better for me than you might expect. I'm thinking of building one and adding it to my list of antennas to compare, and I'll get it up about 35' feet, and post my results here on WWRF.
Good luck, and keep us posted.
Awesome. That Archer 21-901 Ground Plane was the exact antenna that I was thinking about! Interestingly, in the picture it appears that the radials go straight out and are not sloping downward like most ground planes! (The old Lafayette CB ground plane had sloping radials). Perhaps the fact that the elements are 108 inches might have something to do with it? Hmmmm.
Just when I thought I knew 1/4 wave GP's, I get thrown a curve ball (so to speak)...I could NEVER get a true 1:1 match. Best I could get was around 1.5:1 - not too bad, just not 1:1.
With making a GP, Has anybody ever achieved a 1:1 match with a 1/4 wave GP (without using the tuning stub shunt method)?
Bob, KD5MHQ
Marconi,
Is the hub in the pic from an A99 or is it one of your homemade ones?
Also, will a GP with a single sloping radial perform as well (in the direction the radial is pointed) as one with 4 radials?
Thanks!
