Couple of questions about mounting a dipole antenna...
Is there a minimum mounting height for a dipole? Obviously with any antenna the higher it is the better, but outside of this, is there a minimum height for it to be mounted so that it radiates properly and/or the ground doesn't interfere with it??
The antenna is currenly hanging horizontally about 12 feet off the ground. I am receiving local stations with vertical antennas pretty well. I had expected this horizontally mounted antenna to attenuate vertically polorized signals while optimizing 'flat side' stations. Since the antenna is acting more like a vertical I am wondering if I am over estimating the attenuation effect or whether or not it really is behaving like a vertical because it is not high enough off the ground. Related to my first question, is there a minimum height before I see it act like a horiztonal antenna?
Thanks
Thanks
