Build it!!!
I use 1/2 EMT conduit for most of my home brew ground planes AND yagis, bit on the heavy side but they work well and cost pennies on the $$ compared to aluminum tubing.
And I can get the EMT conduit at the local big box stores.
As for those who say it will rust, yes it will but the so 239 and coax may fail long before the galvanized emt conduit does.
Use what you have on hand, so many arm chair perfectionists with keyboards now a days.
Build it have fun and make some contacts.
IF you are going to make a three element you may need a matching device at feed point, either gamma, or t match or hairpin match etc etc, to bring up the impedance to 50 ohms.
Or the spacing of the elements will also change the impedance of the yagi.
