ok so ive got 2 five foot stainless steel base loaded mag mount antennas laying around that i dont use, woudl it be possible to set them up and use both as a dipole antenna, i was thinking about running the setup vertical, so i was going to run the braided wire to the bottom antenna and the tx/rx wire to the top one, would this work or would it backfire on me, i have a wire dipole setup vertical but every adjustment im makeing is making the rx worse, ive got good tx with it but bad rx, so any thoughts or suggestions would be helpful,,,, thank you mark
