Thanks to everyone for the help with my previous questions about dipoles for cb. On the subject of lightning protection, I think I've just about reached the end of the internet, and im still unclear on what to do. Lots opinions from fancy expensive protection systems to very simple advice to just disconnect the antenna.
Setup will be simple: Uniden grant ssb with 10 amp power source in garage. Dipole will be in yard strung up between two trees. Coax run back to cb in garage. Here are a few questions.
1. As far as lightning protection goes, it seems the best thing is just to disconnect the darn coax OUTSIDE when not in use. If so, should i ground the shield of the coax to a grounding rod near where the coax comes down from the dipole, away from the house? Not sure if this is necesary, or if it would do any good anyways if hit by lightning. Wondering if grounding it might help prevent damage to the coax if hit, or if grounding would help eliminate any noise from static, etc.
2. In order to disconnect the coax outside, i'd need to do some sort of connector. Id run one section of coax from the radio out through the garage wall to connect to the coax outside running to the dipole. Any special connector needed? What woudl you recommend.
3. As far as the coax lead running from the dipole to the garage, does the lead need to be raised above ground, or can it run on the ground to the garage, or even underground in a pvc pipe. Stringing it up would be a pain. Thinking of just coiling it up and hanging it on a tree under the dipole when not in use, so having it lay on the ground when in use is no big deal. Just want to make sure this didn't reduce performance. Thanks again!!!
