Right now I'm running no ground on my homebrew 5/8 GP. its about 35 ' up in a pine tree. I do have a small copper pipe driven in to the ground rith outside my window with a wire I attach to the outer connector of coax right at the back of radio for stray RF. Not sure if this actually does anything or not. I usually just unhook the coax ad put in a glass canning jar in case of lightening strike. I figure the antenna will be destroyed regardless if it is grounded or not and its away from the house in a tree. . I was just reading a write up on how grounding with minium 3 copper rods from the elevated gp antenna will improve its performance aside from lightinging saftey. also adding full wave length radials on the ground going away from the ground rods will help with reflection.
Any truth to this and is it worth doing aside from a saftey standpoint? I have read about as much as i can find on this and I am still confused about weather It is needed or not.
