DO THEY MAKE TOWER HAZERS THAT WORK WITH UNIVERSAL TOWER??
TonyV225
Apr 18, 2005
5,824
323
143
Wisconsin
I have a large tower going up and I was checking into the tower hazer to avoid having to climb the tower for work needing to be done or lowering the beam when storms come in. I am just wondering in these ar for RHON TOWER or if they will work with UNIVERSAL TOWER aswell? I know the Rhon has 2 bolts that are horizontal through each leg and the Universal has one long bolt that goes vertical through each leg so I was curious or afraid if these available hazers would still work?
If the face of the Universal tower is the same width as Rohn 20 - 25, then they ought to work, I think. Being naturally cheap, I made a 'Hazer' once to fit a Universal tower. Didn't get it up, nothing to do with the hazer, was something else. The Hazer slides over any normally protruding bolts holding the sections together. Or, if you're really desperate, you can put 'rails' on the tower face for it to slide on.
Not putting the tower up had to do with city restriction.
    535A has left the room.
  • @ AmericanEagle575:
