Dual final hi power dead key?
Just watched a video on Bells cb, after his tune up that one was dead keying on high at 10 watt, on low it was 4 watts.
If it has a hi lo button 2 & 8 work well. If variable 1-8 is good for dialing in an amplifier. I'm too lazy to check but the factory spec alignment info at cb tricks will show the suggested numbers. Since these new mosfet radio's seem to swing a bit more 10 watts on hi would be fine.
