Not exactly. When signal is bumping against ionosphere layers it's twisting.but I still kinda think verticals don't make much sense,I mean correct me if I'm wrong but most people use horizontal right? and if you use a vertical and the other guy uses a horizontal antenna then you are going to loose 20db right off the bat right? so if most people are using horizontal antennas then you are starting off at a loss for contacts... I'm I getting this right?
