I have moved into a duplex and am trying to figure out my best bet for an antenna. Obviously no A99s in the air or dipole strung across the yard.
My idea was to see if I could run a dipole horizontally around my back porch. It is not long enough to string it straight so it will have to turn 90 degrees. It would still be completely horizontal though. The ceiling of the porch is wood with no metal visible.
My only concern is the turn. Will this effect anything? Would it be better to turn it 90 degrees downward so it's vertical? I am aiming for DX and not local traffic.
Thank you,
Clark
Thank you,
Clark
