@#%&*% dx500v buttons
dxing440
161
10
#5$@ ^%@* just popped the receive and variabl butoon off. How do the go back on or come off. I may have broke them?
Theyre broke. Half the white tab is still inside the buttons.ANYONE know wher to get replacement switches?
That is a little confusing...
Are you talking about the green and white plastic lens that covers the switch?
They do not have plastic tabs holding them in.
The pop into the inside of the black outer housing on the switch.
That whole black outer housing is what slides back and forth to activate the switch.
Can you see the bulbs if you look down inside the switch?
I think you can get replacement switches from RFParts in San Marcos, CA
yes, the white and green lens`s are still attached to the black buttons, you can see the switch itself, the bulbs in the amp, and the inside of amp. Ill try the place you named above.
