first of all, forget about stacking. you can come back to it later after you wrap your head around this for a while. you are obviously reading articles on the subject and wanting to take a shot at it without understanding the operational basics and principles of a simple antenna. that and the terminology are creating the confusion you're experiencing. don't worry, this applies to all antennas, including your yagis.
every antenna, when energized by the transmitter, creates an ELECTRIC FIELD that exists in the SAME PLANE in which the antenna is oriented. this is the E-PLANE. in other words, if the antenna is vertically polarized then the E-PLANE is vertically polarized. on the other hand, if the antenna is horizontally polarized then the E-PLANE is also horizontally polarized. simple enough.
if we follow one cycle/hertz of transmitted energy for the full 360 degrees, here is what is happening.
at 360/0 degrees the transmitter and the antenna are energized and the electric field charge begins to develop.
at 90 degrees the electric field charge in the E-PLANE reaches maximum potential.
at 180 degrees the electric field charge collapses, generating a developing magnetic field charge in the plane perpendicular to the collapsing electric field charge. this plane is referred to as the H-PLANE.
at 270 degrees the magnetic field charge reaches maximum potential.
at 360/0 degrees the magnetic field charge collapses, generating another developing electric field charge and the entire process begins all over again.
if the operating frequency is 27 mhz then this entire process occurs 27 million times a second. this is how the antenna radiates a signal. this is the process responsible for generating an ELECTRO-MAGNETIC wavefront.
292 Radio Shop / FireCommunications Network
