  • Flash Feb 2025 Radioddity Giveaway! Click Here to enter!
ELECRAFT KX3 FIRMWARE UPDATE MAC OS X
Happy_Hamer
Administrator
Staff member
Mar 22, 2001
5,062
211
123
After pulling my hair out trying to figure out why my Mac would not detect my
KX3, I posted the question on the Yahoo Group for help.
After about 5 minutes I got a call from Dale at Elecraft.
Here is my K.I.S.S. Firmware Upgradde Instructions.
DO NOT PLUG ANYTHING IN YET!
Download KX3 Utility for MAC OS X and install
Elecraft® Hands-On Ham Radio™
Download the FTDI Driver dmg file for MAC OS X
Virtual COM Port Drivers
Once downloaded, follow the driver installation directions, you will need to
enter your system password to authorize the driver install.
Open the KX3 Untility
Connect the KXUSB cable to ACC1 of the KX3
Connect the other end of the cable to your MAC
Click Refresh Port List
Select usbserial or similar for your port, mine is listed as usbserial-A4014ASC
Click Test Communications
Once your KX3 is detected, click the Firmware tab
Click Check Versions Now
I already had the new version (1.02) saved on my hard drive so I just browsed
for it and hi lighted the folder it was in and hit select.
I then clicked Send All Firmware to KX3
Sit back and watch, don't touch anything until is shows ready.
When I installed 1.02 it installed two sets of firmware including the DSP Update.
I did not use the Copy New Files From Elecraft since I already had the file I
needed, so someone else can chime in with what to expect when doing it that way.
Thanks Dale!!
