9
995
Guest
The noise in my receive that is. All along....that's what I thought it was. A few days ago I built a simple DC filter. Something I've had on the back burner. I used an iron core choke and a few capacitors. Low and behold....it didn't work. I disconnected the serpentine belt and IT WAS STILL THERE. So that rules out the alternator. LOL. Low and behold...it's coming through the coax...not the DC power wires. I have the cab grounded to frame....exhaust grounded...doors grounded, hood grounded. Nothing has made a lick of difference for better or worse. When I try the coax loop sniffer, I get nothing but a crackle whenever near the metal. I assume this is the spark plugs.
High pitched whining, only when throttle is above idle, raises pitch with RPM. Receive is silent with coax disconnected. Any ideas?
