Emperor 3010 no transmit
Bub73
Apr 8, 2005
30
Anyone with a voltage chart for a Emperor 3010. I have one with no transmit in any mode. receive seems ok but no S meter bar graph and the PA works fine also..........
Bub73
I would check to make sure mic is all wired solid in the plug simple place to start I have seen problems solved at this stage otherwise i would think final transistors went kapootski. Roger Bird would most likely have your charting for the voltage on that rig. Im sure he will be along shortly...
wizard50wy
voltage regulator? overheat/no pwr/check Vin & Vout /my start point.after mic/visual exam/..this problem.
lucky 73's to you.
Thanks for the reply;
The voltage regulators seem ok and every thing runs cool . I don't know what voltages I should be seeing on the IC's etc. Not much info for the 3010 on the net.
Thank's
Bub73
