Chris, what do you think, I have a 5010 / Lincoln that puts out too many watts (even adjusted internally) and doesn't have "CB Dynamics". Don't get me wrong, the radio TALKS but it has too many watts for my "Driver".
So, I was thinking about lifting the base on the 2166 driver from the board and inserting a 10 ohm resistor between the base and the circuit board; this will knock the output down (?).
Also, on the circuit board end of the newly added 10 ohm resistor, I was going to add 330 ohms to ground; this will give the radio "swing".
I've been looking at the H. W. Sams for the old circuits in the Cobra radios for ideas, what do you think?
