Then I ask, why do I pick up more trash in the 11 meter band than the 10 meter band? Significantly more trash. The speed sensor translates ac pulse and it tears up the radio in 11m. 10m it's almost gone.
Tuning is NOT the issue. You need to cure the problem at the source, and that source is NOT inside the radio. The reason you hear it more on 11m is simply because the radio's receiving circuits are peaked in that range and sensitivity is better.
