SARGE,
The 'coiling it up' thing is another one of ~those~ tales you hear. For all practical purposes, coiling coax feed line doesn't do any harm unless you coil it too tight, as in very small coils, which can cause conductor migration, and deformation. For 'RG-8' size coax, anything smaller than about 4 inches in diameter is too small. Making a choke out of coax works because of currents flowing on the outside of it, not on the inside of it. You want to stop the 'outside' current, that's the one that causes interference. The 'inside' current is the signal, and nothing happens to it. So, unless theres another problem, coiling coax doesn't do any hard (inna truck, the yard, whatever). If you want to make 10 feet loops, no problem. If you want to make 3-4 foot loops, no problem there either... just keep the lawnmower and weedeater away from it.
